41 Users Online (39 Members):
Forums >> Revit Systems >> Technical Support >> graphic problems with lighting fixtures
I've made several custom lighting fixture families and included a 2D solid white fill detail component to use as a "symbol" in an actual drawing. I've set the VG settings so that only the 2D elements show in plan view, not the 3D elements. The families themselves look as I expect them to with these settings. But when I put them into a project, the 2D elements don't show up. With one of the families, I see the 3D drawing. With the other 2 families, I see only a black box (these are troffers). I can't figure out what is different between these families- they are all similar fixtures built the same way- and I the VG dialog box doesn't seem to offer an options that will fix this problem. Any ideas? Thanks in advance.
jlights |
We would have to look at your families.
Lighting fixture problems |
Wed, May 10, 2017 at 9:52:09 AM
13
How to show lighting fixtures on floor plan |
Mon, Nov 6, 2006 at 10:15:38 PM
create a new lighting fixtures |
Fri, Aug 15, 2008 at 10:54:54 AM
Lighting Fixtures |
Thu, Apr 24, 2014 at 6:13:26 AM
Lighting Fixtures on Walls |
Mon, Aug 30, 2010 at 12:39:30 PM
Members: | 2019237 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
