51 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curtain Wall/Screen tag and schedule
Sun, Jul 13, 2008 at 10:57:54 PM | Curtain Wall/Screen tag and schedule
PaulM3357
I'm try to setup tag for curtain wall/stroe front screen for a retail project. Also trying to extract the curtain wall/screen quantity in a schedule. I'm not able to locate a tag for curtain wall similear to window tag. If there is no tag dedicated for curtain wall than how can I extract the width and length of the curtain wall segments in a schedule? Any help or suggestion will be appreciated.
Tue, Aug 26, 2008 at 11:20:10 AM | Curtain Wall/Screen tag and schedule
twhisker
2 Stars: 4 Votes
Here is a tag I created for our walls.  There are 3 types: wall only, wall with ceiling condition (shared parameter created for walls), and storefront.  You would have to assign the tag ofr walls and most liely the default is wall only type.  Then when you tag the storefront, change it to the strorefront type.
The only drawback is that a hexagon (window shape used for storefront) is larger than a square (wall shape).  Even though the hexagon is turned off in the visibility for the wall tag, the leader line only goes as far as the hexagon and there is a gap between the leader and the square tag.  You most likely have to try it out to see what I mean.
Does anyone know of a way to create 2 distinct tags for "curtain walls" that are storefronts?  It's been a bothersome issue here in the office that curtain walls and storefronts are lumped together with walls.
Revit Architecture 2010
Tue, Aug 26, 2008 at 11:22:32 AM | Curtain Wall/Screen tag and schedule
twhisker
2 Stars: 4 Votes
My apologies - the wall tag was created in 2009.  We just converted this week.
Tue, Dec 30, 2008 at 4:00:49 PM | Curtain Wall/Screen tag and schedule
PaulM3357
Thanks Twaisker!
Your suggestion was much appreciated.
Tagging Curtain Walls with a window Tag?
Wed, Mar 11, 2009 at 4:01:11 PM
Reporting parameter from curtain wall door in Curtain Wall Schedule
Mon, Dec 19, 2022 at 5:44:59 AM
11
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:12 PM
Curtain wall schedule
Wed, Nov 19, 2008 at 1:26:14 PM
Curtain wall model group
Thu, Jul 21, 2016 at 8:04:08 AM
Page generation time: 1.2577
