59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Behaviour
Sun, Jul 13, 2008 at 12:49:42 AM | Wall Behaviour
akome555
Hi,
I had this wall cladding that Id like to align along the face of the column. Every time I try to move it, it always move automatically and trim with the Insulated wall I place to cover the column. How do I control the wall from automatically moving and joing the other wall.
Revit 2008.
Sun, Jul 13, 2008 at 7:49:06 PM | Wall Behaviour
Luckydug
3.5 Stars: 3 Votes
I don't know if this helps but try - select wall right clck over wall end and select disallow join from menu then use your 'move' command and check the disjoin box before moving the wall.
Sun, Jul 13, 2008 at 11:49:18 PM | Wall Behaviour
akome555
Im lucky, lucky dug.
It work. Thanks.
Weird Window-Wall behaviour
Tue, Oct 19, 2004 at 2:21:32 AM
Dormer wall attachment issue
Fri, Apr 15, 2011 at 1:42:00 PM
Tag Leader Origins
Thu, Mar 17, 2005 at 12:45:31 AM
Texture behaviour with new family from imported 3D object
Tue, Sep 27, 2016 at 6:58:11 AM
11
Concrete columns behaviour before and after placing concrete beams
Tue, Apr 1, 2014 at 1:58:43 AM
Page generation time: 1.4191
