Forums >> Revit Building >> Technical Support >> Loading objects from the Imperial Library
16 Posts No Rating |
Everytime I try to load something from the Imperial Library, I get this error, and Revit has to shut down. What the hell is going on? I thought this was only an issue with older objects from previous versions of the software, but I downloaded some objects for 2009 and it still gives me this error. Any help would be great. When is Revit going to come out with a patch to fix this? Revit 2009 Architecture Windows XP pro
Hi JZ, did you install the Service Pack to Revit 2009 Architecture?
Service Pack? Does it fix these issues? How about for objects that aren't modeled in 2009? This is becoming a pain because I have tons of objects downloaded from this great forum, but can't use any of them! Thanks for any help!
OK, if you can't use any object download from this site, i think you must re-install the Revit, so go to this link: http://www.revitarchitecture2009.com/ or here: http://bimboom.blogspot.com/2008/06/revit-mep-structure-and-architecture.html and download the SP...
Edited on: Sun, Jul 13, 2008 at 8:13:27 AM
Just uninstalled Revit 2009, and went to the link you specified and downloaded and installed Autocad 2009. I still cannot load any objects into the program besides the standard ones that come with the program. What is going on here? Am I missing something? Please, someone, help. Thanks, Jimmy
I have attached Print Screens of the error messages I get. This is getting ridiculous, and I need to finish some of these renderings for clients.
Ok JZ, what kind of machine you use? Caracteristics of CPU, RAM, graphic? i don't know but i think it's like "out-of-memory"...
Here are my Specs: Intel Core 2 Duo 6420 4 GB Corsair XMS2 DDR2 6400 2 HardDrives: Maxtor & Western Digital (Over 360GB Space) Windows XP Pro SP3 Graphics: XFX Geforce 7900GS 256MB DDR3 PCI EXP-16 256Bit Anything else you need to know? Thanks for any and all help.
Yeah, it's like my machine, but i only have 3GB RAM and my graphic it's ATI RADEON 512mb, some times i had that error until i upgrade to SP1 of 2009, just revit it's not multi-processor i use SMP-SEESAW to isolate revit in one CORE until i work, try to do that, install SMP SEESAW and open revit, then run SMP SEESAW and choose revit and isolate in CPU1, then work normally, Hope This Help...
Well....I did what you recommend. I installed that program. I opened the Revit Drawing. I than started up that program and isolated Revit on one of the CPU's. Tried to load an object....same error????????????? Anyone with a solution to this??!!
What object are try to LOAD? do you OPEN that OBJ. or you try to OPEN that OBJ.? can you put that OBJ. here to download for i try to figure out?
It does not matter which object I try to load from the Imperial library...if it was downloaded, it causes an error. Every object that comes with the software, loads fine. This is a true annoyance.
Imperial Library Didnt Install |
Sun, Oct 9, 2011 at 10:14:27 AM
Library Components, Metric and Imperial |
Mon, Apr 30, 2012 at 12:38:59 PM
Switch from 9.1 to 2008. Network libraries etc. |
Wed, Oct 10, 2007 at 8:03:19 AM
Imperial Library |
Thu, Nov 9, 2006 at 4:59:32 PM
Refreshing Imperial Library |
Tue, Oct 21, 2008 at 9:17:49 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
