89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> TOPOGRAPHIC ELEVATION CHANGE
Sat, Jul 12, 2008 at 1:39:38 AM | TOPOGRAPHIC ELEVATION CHANGE
akome555
Hi,
Im using Revit 2008. How can I change my existing model elevation leve to topographic elevation.
Sat, Jul 12, 2008 at 4:08:49 AM | TOPOGRAPHIC ELEVATION CHANGE
4 Stars: 202 Votes
Hi Akome, first of all you must change your units to "meters" because you want your levels in meters, then dimension ALL levels and LOCKED, after this change the first (bottom) level to "206.4m", ZE and now you can delete the dimensions...
Sat, Jul 12, 2008 at 5:37:19 AM | TOPOGRAPHIC ELEVATION CHANGE
akome555
Typhoon,
The idea is to change the only level Elevation in meters. the dimension in plan should remain in millimeters. Is there a way to overide it?
Also,the site topography did not go along with the changing of levels, there is an included building pad that needs to be readjusted.
Sat, Jul 12, 2008 at 5:45:46 AM | TOPOGRAPHIC ELEVATION CHANGE
4 Stars: 202 Votes
"The idea is to change the only level Elevation in meters. the dimension in plan should remain in millimeters." - You can't do that, if you change the units affect all project and not only the level elevation...
Wed, Sep 16, 2009 at 12:27:26 AM | TOPOGRAPHIC ELEVATION CHANGE
rudyard
1 Stars: 1 Votes
This is certainly possible.  What you need to do, is edit your elevation head markers family, in the family editor, select the 'elevation label' and then select 'edit label', in this screen under 'label parameters' ---> 'parameter names', select 'elevation.
Then a little hand icon below that box ungreys out and you can select it, its called 'edit parameters unit format'.
In here, delselect 'use project settings' and then change it to meters.
 Now any elevations/sections using that elevation head will display in meters as it should whilst the rest of the project will display in millimeters as it should.
Changed Levels to Correct Shared Elevation, now how to change topography points?
Tue, Nov 20, 2012 at 10:34:02 PM
Selecting Topographic Points based on Elevation
Tue, Aug 7, 2012 at 3:16:33 PM
Topographic points
Thu, Nov 27, 2008 at 9:22:45 PM
Elevation level change
Thu, Apr 18, 2013 at 3:06:43 PM
Hiding the edges of a topographic surface
Mon, Nov 3, 2008 at 10:44:16 AM
Page generation time: 1.0584
