65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Light fixture and ceiling problems
Revit 2009 I have a problem wiht my recessed lights. I creadted a celiling and weh I place the lights they end up being like a foot or less below the deiling line does anybocy knwo how to fix this? thanks
----------------------------------- SAGIR |
The best way to create new family is to copy and edit existing ones. There's this sample recessed light in the library that comes with Revit or you can download one from this site. As per your recessed light, your Reference plane should coincide with your ceiling line. Check if it does not. Or you might have an offset value in your light properties. The easiest way is to Re-create your light from start and use a template.
Motto: "No Post left behind" |
46 Posts No Rating |
I was having this same problem when I was creating ceilings as inplace families rather than duplicating. To piggy back on what mhans has said, the best way to remedy this is to create ceilings by duplicating the "Compound Ceiling: GWB on Mtl. Stud" and adjusting the thickness to whatever you want. The recessed can lights should work without a problem then.
Light fixture does not host to ceiling |
Mon, Feb 24, 2014 at 7:14:24 AM
Light Fixture - Recessed |
Fri, Nov 13, 2009 at 9:14:57 AM
Light Fixture on Sloped Ceiling Displays incorrectly in section |
Wed, Jun 1, 2016 at 6:43:11 PM
Opaque light fixture not emitting light |
Wed, Dec 18, 2013 at 3:30:34 AM
light fixture height above floor |
Mon, Nov 9, 2009 at 5:00:09 PM
Members: | 2042257 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
