76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Doors that goes through 2 walls.
![4 Stars: 12 Votes](/images/stars_4.gif) |
Hi, Using 2009 rac. I am working on a project where there are 2 walls side by side (see image below) Blue wall is the structural wall and grey is our architectural wall. Firstly they have to be seperate walls and not a compound wall. I need to put doors in. I have different ways around this from editing one of the wall profiles. Placing an opening in one of the walls. or adding in a second BLANK door. Can i ask how other people deal with this.
I just use join geometry and the dorr cuts both walls.
![coreed Avatar](user_avatar/14568.jpg)
"I just use join geometry and the dorr cuts both walls." i find this method the best also.
you know sometimes i think stupid, i never tried that, its so obvious. this is the problem with when u teach your self. cheers guys that is definatly the best way.
I won't take credit fro this one because I think coreed first put me onto it.
42 Posts No Rating |
One question. If you join them, will wall tags reflect each wall's info? I had the same problem, but I solved it by doing a wall opening on one wall and placing the door in the other. Sort of does the trick... and keeps the walls independent from each other...
The join geometry works without losing the definitions of each wall. Therefore the walls still tag and no need to use the opening, just the one door.
Walls/doors behaving VERY strange in v.2010 - PLEASE HELP |
Wed, Sep 30, 2009 at 8:10:53 AM
Doors, Door jambs, and placement in walls |
Fri, Feb 22, 2013 at 9:30:07 AM
Windows and doors not showing up in walls |
Mon, Nov 8, 2010 at 3:24:05 PM
Curtain walls vs doors & windows |
Sat, Oct 15, 2016 at 4:16:00 AM
Doors not appearing in door schedule... Help |
Thu, May 30, 2013 at 11:58:43 PM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
