121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> wall by face, base geometry dont show
Fri, Jul 11, 2008 at 2:46:34 AM | wall by face, base geometry dont show
Lonnroth
Revit Architecture 2008
 Hi. new to this, probably a common question.
I made a mass out of one extruded solid (base half semiellips, half semicircle) and then cut it diagonally (in section) using to voids set in two different workplanes before exiting the mass-tool. Geometry looks peach, but when i want to create walls out of the geometry, using wall by face, only the semielliptical part follows the geometry. The semicircle part do not recognize the slants in section, but appears as a simple half-cylinder (the base-shape).
What do I do wrong?
Fri, Jul 11, 2008 at 3:46:19 AM | wall by face, base geometry dont show
Lonnroth
ok
I basically solved by not using a partial ellipse plus a semicircle as base-geometry for the extruded solid. I used two partial ellipses instead. One of the with the axis' as the semicircle.
weird problem, though, or is it a glitch in the software?
Fri, Jul 11, 2008 at 4:11:20 AM | wall by face, base geometry dont show
Lonnroth
ok
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:38 PM
wall by face
Wed, Sep 19, 2012 at 12:25:51 AM
Roof by Face and Wall by face tools
Tue, Jan 28, 2014 at 6:31:04 AM
Can Revit show base elevation line where it cuts topography? [ 1 2 ]
Fri, Dec 2, 2011 at 1:53:58 PM
20
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:09 AM
Page generation time: 3.0762
