43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 Wall finish wrapping around columns
Thu, Jul 10, 2008 at 11:00:33 AM | Revit 2009 Wall finish wrapping around columns
Asidie
Hi all.
I want to know: I draw columns that are round, concrete columns.
Then I added walls. My question is, when a wall goes across a columns, the wall finish wrap around the columns. Is there a way to avoid that, I mean drawing a wall that goes across a column without the finishes layers wrapping?
Thanks to all!
Math.
Thu, Jul 10, 2008 at 4:33:44 PM | Revit 2009 Wall finish wrapping around columns
Thread Post Kudo! #2
Use a structural round column.  The REVIT base column is areally a pilaster and it assumes the finish of the wall it touches.
Fri, Jul 11, 2008 at 8:46:22 AM | Revit 2009 Wall finish wrapping around columns
Asidie
Thanks!
Is there a way to make the slab structural in Revit architecture 2009?
Merci!
Wall finish wrapping at two different walls that intersect
Thu, Mar 6, 2014 at 8:47:24 AM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:11 PM
12
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
Problem with intersections between slabs(with finish)and columns
Fri, Dec 28, 2012 at 11:31:58 AM
Wall wraping in windows and structural columns
Mon, Feb 2, 2015 at 11:58:44 PM
Page generation time: 2.2014
