32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Slanting Wall vs Window inserts
Tue, Apr 12, 2005 at 9:55:06 PM | Slanting Wall vs Window inserts
ale02
ale02 Avatar
3 Stars: 3 Votes
Is there any easy ways out of this... Let say we have a in-place slanting wall (refer attached JPG) and we would like to have a window on it, current insert window techniques would end up giving the results as shown in the attached JPG. As far as I could think of is to create a opening on the slanting wall and create a separate window using generic model (properly by introducing a radial parameter/ or using reference line) so that allow the window to rotate & fit to the opening..Is this the only solution...Any other easier workaround??
Life is never easy but nor it should be complex. Just stay simple Smile
Tue, Apr 12, 2005 at 10:31:58 PM | RE: Slanting Wall vs Window inserts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'd duplicate the family and create another window family created from blends and then add a formula to calculate the offset of the blend given a particular angle... In the real world there would be a need to create a specific window type for this instance, as such you have to in revit also...
Wed, Apr 13, 2005 at 12:14:00 AM | RE: Slanting Wall vs Window inserts
ale02
ale02 Avatar
3 Stars: 3 Votes
Thanks for the workaround, Mr Spot.. I think your method is better than me cause properly your window can be parametric and as my workaround proper very rigid in the sense of getting them work properly.. btw, can you upload that the window you are mentioning for my reference..Not too sure how to apply formula in this case by using "blend" window. Thanks in advance
Wed, Apr 13, 2005 at 2:02:47 AM | RE: Slanting Wall vs Window inserts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I never mentioned a window... lol Formula would be just some simple trig... Dimension off the base blend in your top blend and add a parameter for offset and group under constraints. Then go to your family types and add a parameter, angle and call it wall angle/slope or whatever suits your fancy. Then utilise a little trig to get: Offset = (Tan (90-Wall angle))*Height Or something like that, depending on how yours is setup. HTH.
Wed, Apr 13, 2005 at 3:40:32 AM | RE: Slanting Wall vs Window inserts
ale02
ale02 Avatar
3 Stars: 3 Votes
Quoting Mr Spot - 2005-04-12 22:31:58
"I'd duplicate the family and create another window family created from blends and then add a formula to calculate the offset of the blend given a particular angle..."
Haha...My mistakes in the sentence..
Anyway, will get it a try on the formula.
Post edited on 2005-06-13 04:06:41
Wed, Apr 13, 2005 at 3:56:19 PM | RE: Slanting Wall vs Window inserts
bayou66
3 Stars: 1 Votes
I would just love to know how you made the wall slant!
Wed, Apr 13, 2005 at 10:37:40 PM | RE: Slanting Wall vs Window inserts
ale02
ale02 Avatar
3 Stars: 3 Votes
bayou66, Just use create-in place wall family>extrusion and sketch your slanting wall profile in sections/ elevation. You can use solid sweep as well but in this case, I used extrusion Regards,
Tue, Apr 19, 2005 at 7:51:49 AM | RE: Slanting Wall vs Window inserts
Arnel Aguel
Here is a nice work around using curtain system.
slanting wall
Sun, Sep 20, 2009 at 8:45:30 AM
WALL WRAPPING AT INSERTS PROBLEM
Thu, Jan 29, 2015 at 6:56:17 AM
Wall Layer Wrap At Inserts
Thu, Jun 11, 2015 at 11:10:10 AM
HOW TO CREATE A SLANTING STRUCTURES USING REVIT 2014
Wed, Jul 9, 2014 at 8:23:04 AM
wrapping of wall inserts
Fri, Jul 14, 2006 at 5:13:18 PM
Page generation time: 1.4929
