55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Drop Slab
Tue, Jul 8, 2008 at 8:49:50 AM | Drop Slab
akome555
hi,
Im creating a drop slab floor. How do I do it without creating a new floor and lowering the base offset. Just a single floor slab with a drop with the perimeter of the column.
Thanks.
Tue, Jul 8, 2008 at 9:14:43 AM | Drop Slab
You can do as you suggested and copy it to multiple locations or you can create a family and do the same thing.  The slab thought is probably easiest.
Tue, Jul 8, 2008 at 12:04:41 PM | Drop Slab
shaverjeff
I would recommend the external family approach.  It allows you to more easily constrain the panels to the columns/grids.  This ensures the drop panels are always centered on your columns even when they are shifting about in the early design phases.  Depending on your modeling techniques you could create a family hosted on your column or slab.  Personally I use a custom family created from the "complex beam and trusses" template with type parameters for the width and length.  Depending on the project thickness can be controlled with either an instance or type parameter.
Tue, Jul 8, 2008 at 12:57:06 PM | Drop Slab
What's good above shaverjeff's answer is that if you make his parametric family, it could be used on multiple projects in different ways.
Wed, Jul 9, 2008 at 12:43:04 AM | Drop Slab
akome555
WWHub,
As you suggested, my method would be fine but if i Section it, it will have a line showing incorrect view.
Shaverjeff,
Can you show me how to do it. step by step, or at least the basic procedure. not very familiar with hosted family.
thanks.
40155_003.tif
Wed, Jul 9, 2008 at 12:45:04 AM | Drop Slab
akome555
sorry for the wrong image above.
Wed, Jul 9, 2008 at 12:57:16 AM | Drop Slab
akome555
WWHub,
I figured it  out, I'll just join geometry.
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:02 AM
how to create a drop cap step?
Sat, Jan 30, 2010 at 4:33:01 PM
foundation drop
Tue, Apr 14, 2015 at 1:38:40 AM
new slabs, existing slabs, and the nature of constraint(s)
Wed, Dec 11, 2013 at 12:21:25 PM
Slab tag positioning
Thu, May 14, 2015 at 8:43:39 AM
Page generation time: 0.2778
