Forums >> Revit Building >> Technical Support >> Invisible Dimension Lines
15 Posts No Rating |
I am using Revit 2009. Is there ANY way to make the dimension lines invisible? NOT white, or 1point thickness, INVISIBLE... I really hope there is. thanks.
thanks,Simon. |
You can set the dimension line thickness but the lowest you can go is 1 and the 1 weigth is the default for a lot of items so I would not change that. Perhaps you can rework the lineweight chart using the 16 pen and making that very small? Let us know what you discover.
The best we could do was to direct the dimension line to an Annotation Line Weight of 0.025mm which is the smallest possible. It is hardly noticeble on final plots - better than nothing I suppose.
thanks,Simon. |
What part do you want invisible? The tick line, witness line or all of the dimension lines?
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
We want all of the dimension lines invisible, so only the text remained. I can shorten/remove most of the tick or witness lines, but the main dimension line is the tricky one.
thanks,Simon. |
You cant make the bit under the text invisible, only change its colour or thickness. There is a "fake" dimension line around where you can change the linetype etc, but using this is very time consuming. I'll upload it for you so you can have a play with it. It's under detail component, and when you use it make sure you lock it onto whatever your dimensioning. But really what you suggested earlier with the lineweight thing is the best work-around.
Perhaps it wasn’t possible in 2009, which is what you were using when this was posted, but now with RAC 2012, what you are asking for takes a minute to make. Have a look at the attached file. I’m guessing it is what you describe you want. The two dims closer to the object are the ones you ask for and the other two, that are further out from the object, are just normal dims I placed for comparison.
And if you go further you could also set the text size to almost 0, which makes it invisible to the eye. That method I used to lock the 90 degree angle on some walls, which obviously had to be perpendicular, but since everything kept being rotated, everything else previously perpendicular to it was no longer so. Putting the ‘invisible’ dimension and locking it made sure that if I rotate more things would remain perpendicular to each other
Invisible lines removed from Line Styels |
Mon, Feb 21, 2011 at 12:10:18 PM
Dimension String |
Wed, Nov 22, 2006 at 3:05:15 PM
Invisible Lines Can't Find Them |
Thu, May 14, 2009 at 8:38:06 AM
Revit 2009: Invisible lines displaying as dashed lines |
Sat, Nov 14, 2009 at 11:57:17 AM
11
Invisible lines not visible in Sheet view? |
Wed, Dec 17, 2008 at 3:47:53 PM
Members: | 2056165 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
