88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Rotate 3D/Planes
Mon, Jul 7, 2008 at 11:06:25 AM | Rotate 3D/Planes
caduk
Im trying to draw some vertical Cable Tray in a sectional view.
Doesn't seem to work!
Pipework/Ductwork does.
Do i need to set up a Plane or there a simple way of doing this!
Mon, Jul 7, 2008 at 12:20:50 PM | Rotate 3D/Planes
rkitect
rkitect Avatar
4 Stars: 29 Votes
Are you going for just a drafted section of cable tray or an actual cable tray object?  Try this if you you want an actual object. (They should open in 2008.  Haven't used them in a while, so I'm not sure how well or even if they work.)
Tue, Jul 8, 2008 at 3:00:47 AM | Rotate 3D/Planes
caduk
Cheers.
It's an actual section (run) of tray im trying to do.
It works well in Plan view. I just need to draw it vertically. (iv'e tried in 3D, Elevation & Section)
Thanks for your Families. I'll download and have a try.
3d Rotate object
Tue, Nov 18, 2008 at 5:08:34 PM
CanĀ“t rotate sloped roof in elevation .. please help
Fri, Oct 19, 2012 at 12:52:07 PM
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:08 AM
Need to Rotate entire building model
Wed, Jan 29, 2020 at 9:26:32 AM
Deleting Refererence Planes
Tue, Jun 5, 2012 at 9:11:29 AM
Page generation time: 0.2883
