97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Dependant View Template
Fri, Jul 4, 2008 at 9:09:21 AM | Dependant View Template
caduk
Making up some View's
Is there are way for applying `INDEPENDANT' View Templates to views which have been created Dependantly.
We need to keep the Dependant views together in the pull down.
Say for example:
ELECTRICAL
Basement small Power Layout
Basement Lighting Layout
and so on.
Any ideas!
Cheers
Mon, Jul 7, 2008 at 9:19:04 AM | Dependant View Template
rkitect
rkitect Avatar
4 Stars: 29 Votes
The idea behind Dependant views is that they are identical in content, meaning you wouldn't be able to apply a different view template to 2 views that are dependant upon each other.  What you CAN do however is begin assigning your views to a discipline (through the view property dialogue box).  Then sort your Project Broswer by discipline (through the Project Browser proprty box).
Edited on: Mon, Jul 7, 2008 at 9:21:41 AM
Edited on: Mon, Jul 7, 2008 at 9:21:52 AM
Mon, Jul 7, 2008 at 10:20:13 AM | Dependant View Template
As rktect says, dependent views are really just a multiple views of the same information so be careful with that term and how you use them.
We like to control where views are in our browser so we have added a shared parameter (we call it drawing type) that allows us to do that.   If you add a parameter like that then right click on your browser (Views), you can add new view types that will allow you to sort in any manner you choose.  In our system under this new parameter for hotel projects, we might have "Guestroom Plans", "Guestroom Elevations"  or maybe we choose to sort by room types and we will use "King", "Queen" ...  Because this is a shared parameter, it is also now in our view template and we set it accordingly.
Now we rarely have more than 10-15 views under any category.  Even detail views, which we do not assign a view template to, will have this field set so that they will be sub-sorted.
This user is online
Dimension Visability in Dependant View
Wed, May 28, 2008 at 11:50:36 AM
Problem with duplicating view as a dependant
Wed, Jun 3, 2009 at 6:53:16 AM
what are not shared between parent view and dependant view?
Wed, Dec 1, 2010 at 1:01:48 PM
Callouts & Dependant Views
Wed, Aug 13, 2008 at 5:41:42 PM
Girders missing in dependant views
Mon, Jun 27, 2011 at 12:23:00 PM
Page generation time: 1.1366
