96 Users Online (95 Members):
Forums >> Revit Structure >> Technical Support >> Tag Text Length
I have made a new tag family so it calls off what I have in type comments. Is it possible to manipulate the text length once its loaded into a project? I.e I have a large length of text on one item and would like it to wrap onto several lines to neaten it up yet on the other item I have a few lines and dont want it bunched up as much, therefore if I could use the 'grips' like normal text it would be great. Is this possible? TIA
![timbo89 Avatar](user_avatar/48408.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
Hey, from my experience, you can't change the length of the "grip" tabs once its loaded into a project. You can however control what text goes on which line. Using CTRL+ENTER, this creates a hard return enabling text to be put onto a new line. This would probably be the best way to go about it. You have to select the element and go to type properties when using the hard return, as you can't do it on screen. The hard return is classified as a non-printable character, so elements which dont allow them don't allow the hard return to be used. Hope this helps
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
length in beam tag |
Sat, May 26, 2012 at 12:25:40 AM
Shear Wall Length |
Tue, May 24, 2011 at 5:00:45 PM
Room Dimensions in Tag Family |
Sun, Aug 31, 2008 at 9:23:36 PM
Shear wall tag with label that reads wall length |
Fri, Oct 21, 2011 at 5:57:35 PM
View Tag - want to add a second line of text |
Sat, Feb 23, 2013 at 8:30:43 AM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
