98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Array Formula error
21 Posts No Rating |
ok i think there could be a bit of a qlitch here im using RA2009 and i know i have done this before but here goes i could be going crazy. Array family with simple formula ( Parameter(length) / Parameter(integer)  -54mm Now i get the answer calculated in the value field but when i hit apply i get the following error message "Can't find solution for formulas for Type ' '." I have removed the parameter twice and redone it as well as changed the parameter type with still the same responce any ideas. Brett
----------------------------------- Brett |
ok dont worry i found the solution - add the parameter at the array creation stage. It seems you cant use a parameter created before the act in this situation? go figure
Array formula (9.1) |
Mon, Sep 24, 2007 at 7:12:47 PM
Family w/ Array Formula |
Fri, Mar 23, 2007 at 9:29:37 AM
Variable Length Family with Array Formula |
Wed, Aug 8, 2012 at 9:56:46 AM
Array Formula |
Tue, Dec 9, 2008 at 11:11:51 AM
Array Formula Problems |
Tue, Jul 26, 2011 at 2:30:54 AM
Members: | 2017174 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
