50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Volume formula issues
Wed, Jul 2, 2008 at 11:06:55 PM | Volume formula issues
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
OK - Im a total formual Newbe
What I am trying to do is generate a volume formula within my family.
I have set the following attributes
Shelf Volume
Shelf Width
Shelf Depth
Shelf Spacing
Shelf Thickness
Bracket Height
therfore my formula is LxDxH(which I cant get working)
Shelf Volume = (Shelf Width * Shelf Depth) * (Shelf Spacing - Shelf Thickness - Bracket Height) * 4
As there are 4 shelves I add the * 4 at the end.
Can some1 tell me what I am doing wrong???
I wish there was dumb down instructions for formulas :|
Edited on: Wed, Jul 2, 2008 at 11:08:32 PM
Edited on: Wed, Jul 2, 2008 at 11:08:58 PM
Thu, Jul 3, 2008 at 10:32:10 AM | Volume formula issues
rkitect
rkitect Avatar
4 Stars: 29 Votes
Are you getting an error or is the number that you are getting DEFINITELY not the correct answer?
Also, I'm guessing the Shelf Volume parameter is the total volume of all the shelves of the family combined?  Are the shelves uniform or is each shelf a different width/depth/thickness?  If they are uniform wouldn't it be easier to do (Shelf Width * Shelf Depth * Shelf Thickness) * No of Shelves ?
Thu, Jul 3, 2008 at 5:45:31 PM | Volume formula issues
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Im more after the merchandising volume calculation
Thu, Jul 3, 2008 at 11:48:57 PM | Volume formula issues
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Anyone??????
Mon, Jul 7, 2008 at 8:44:09 AM | Volume formula issues
rkitect
rkitect Avatar
4 Stars: 29 Votes
I see now, you're looking for the total volume of empty space between the shelves.  That makes more sense than calculating the total volume of the shelves themselves. :D  If you have a parameter for your side, top and bottom pieces the could befairly painless:
((Height-(Header Height-Footer Height))*(Width-(2*Side Thickness))*(Depth-Back Thickness))-(No of Shelves*(Vol of Shelves)
 Make sense?
Edited on: Mon, Jul 7, 2008 at 8:44:24 AM
Column Volume in Tag
Tue, Oct 4, 2011 at 1:53:31 PM
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Calculating Volume
Tue, Sep 4, 2007 at 2:35:09 AM
Taking off material volume
Wed, Feb 22, 2012 at 4:08:50 AM
conc volume
Mon, Apr 11, 2011 at 9:21:01 AM
Page generation time: 7.3490
