84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Symbolic Lines not showing up in Shaft Openings
Wed, Jul 2, 2008 at 4:10:12 PM | Symbolic Lines not showing up in Shaft Openings
rkitect
rkitect Avatar
4 Stars: 29 Votes
I have a shaft opening that cuts through slabs on 3 different levels.  For some reason, in one of the slabs, the shaft opening shows up, but the symbolic lines that show up in the other level views do not show up.  I had another instace of this happen where I was able to copy the shaft opening and the symbolic lines would show up.  This did not work on this one.  The view range for the view and the top and bottom constraints for the shaft opening are all in proper order.
Thanks for your time,
Thu, Jul 3, 2008 at 11:03:04 AM | Symbolic Lines not showing up in Shaft Openings
coreed
coreed Avatar
4 Stars: 16 Votes
are you using one shaft opening that has a base constraint at level one and top constraint at level 4 ? or are you using multiple openings?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jul 3, 2008 at 11:08:47 AM | RESOLVED: Symbolic Lines not showing up in Shaft Openings
rkitect
rkitect Avatar
4 Stars: 29 Votes
So apparently my brain was off all day yesterday.. the issue was resolved.  Turned out that the lines that were used for the symbolic lines for this shaft were turned off in View Graphics.
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:15 PM
Visibility of Shaft Openings in a detail view
Fri, Apr 17, 2009 at 11:13:43 AM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:49 PM
Potlight Symbolic Lines showing up on other RCPs
Mon, Mar 14, 2011 at 2:41:30 PM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:18 PM
Page generation time: 3.0785
