112 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Tiling
Tue, Apr 12, 2005 at 5:02:29 AM | Tiling
Cypher
Good Morning everybody I would like to use different tilings for my grounds and I would like to know how I can do this with revit... and where I can download several tilings. Thank you very much Cypher
Tue, Apr 12, 2005 at 9:45:29 PM | RE: Tiling
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Do you mean hatch patterns?
Hiroshi Jacobs
Thu, Apr 14, 2005 at 12:49:48 PM | RE: Tiling
Cypher
Yes that's right, hatch patterns for my grounds (kitchen, office, ...). When I try to take a pattern here, it doesn't download (?) and I don't know after downloading how to use it. Thank you Very much
Thu, Apr 14, 2005 at 3:54:32 PM | RE: Tiling
benw
i am also having an issue with tile hatching... the hatch wont show up in my floor plan. any ideas?
Sun, Apr 17, 2005 at 8:17:43 PM | RE: Tiling
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Cypher, Go to Settings-->Fill Patterns-->and add a new model or drafting pattern then use this surface pattern in a material used on a particular surface. (make sure you set the import scale for the pattern by clicking on the name of the pattern after import). You can also do this directly from the material settings... benw, Check your visibility settings for floors-->surface pattern and makes sure its turned on. Surface patterns will not show on ramps. Also check to make sure the material setting for the floor has the appropriate surface pattern assigned, and isn't confused with the cut pattern. HTH.
Tue, Jun 12, 2007 at 10:33:26 PM | Tiling
rudyard
1 Stars: 1 Votes
I know this thread is very old but rather than start a new I thought I would continue in here.....I am trying to apply simple hatch patterns to my plans, in this case im trying to put tiles on the bathroom floor.
Coming from autocad these used to be done via the hatch command, I then select the boundary, then the hatch pattern/scale etc and then click ok.
In revit I think they are called 'fill patterns'??  But cannot find the procedure to actually place them.  Ive been reading the forums and the help but cant stumble across the first command (the hatch equivalent in autocad).
Can someone give me the first step as im having trouble adjusting to the simple things in revit.
Wed, Jun 13, 2007 at 2:51:03 AM | Tiling
Erik
For just hattching, you can use 'fill region' under drafting.  There are many patterns and you can make your own.  Particulary easy are straight 'tile' patters.  Fill regions are view specific and therefor will not show in other veiws or 3d. and you will not get any quantites
I genereally model the way I build.  For floors, I make a structural slab and add a topping floor with the finish.  That way I can have a full structural floor but with differrent floor finish in different rooms Cryingcarper, tiles, timber)  For this case I have in my template file most of my standard 'floors' This is not view specific and will appear in 3d.  Keep in mind that the rendered floor appear different to the 'hattched' floor.  There are 2 settings for material
Thu, Jun 14, 2007 at 11:49:35 PM | Tiling
rudyard
1 Stars: 1 Votes
Thankyou Erik,
For the moment I will only need a view specific hatch but am having trouble getting revit to specify the region.
For example in ACAD the hatch command asks me to select boundaries and it autodetects the region and applies the hatch, going around objects etc.  In have a picture of what I am trying to achieve.
How do I get revit to apply tiles to my bathroom without literally tracing a region around the room and all the objects which would be far to inefficient.   Can it be done as simply as ACAD hatching or is it more built towards setting up templates with floors and materials built in?
Thu, Jun 14, 2007 at 11:50:07 PM | Tiling
rudyard
1 Stars: 1 Votes
Sorry forgot to attach image
Fri, Jun 15, 2007 at 1:17:13 AM | Tiling
Erik
Revit does not 'detect' you room to make a region.  You can however create it by clicking on the walls.  Bathrooms are generally rectangular so it is not a big deal.
To hide the tiling under the fittings is more difficult.
I guess therefor I use a floor.  It is just as easy to make and it is more true to the actual situation of making a virtual model.  It will also look right in section and be calculated with quantites.
I know this does not help you to make Revit like Autocad.  I guess it was never intended to.  At the same time, it would be good to have some of the good things with Autocad across to Revit
Adjust hatching to follow brick courses or tiling for tiling layouts
Tue, Aug 5, 2008 at 10:14:12 AM
Tiling Layout
Wed, Oct 6, 2004 at 1:28:49 AM
Placing filled regions for tiling in bathrooms
Fri, Jun 10, 2005 at 10:35:11 AM
Tiling windows
Thu, Jan 30, 2014 at 2:20:42 PM
Tiling Seamless Texture Images
Tue, Oct 12, 2004 at 8:08:15 PM
Page generation time: 0.1778
