115 Users Online (114 Members):
Forums >> Revit Building >> Technical Support >> Filter walls by floor level or base constraint??
![lorne17 Avatar](user_avatar/39394.jpg)
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
Is there anyway to apply a filter to walls on a specific level or base constraint? Or even height? Any help would be appreciated. Thanks, Lorne
Denver, CO
Revit Architecture |
11 Posts No Rating |
I create a new text parameter and name it mark, building, level, or whatever you want to be able to filter it by. for levels, it easy to use and elevation view, select all the wall in that level, type in what level they are, and then filter it out, or filter the other levels out.
lorne are you talking about selecting and ahocutt are you talking about scheduling?
1 Posts No Rating |
I meet the same problem when I am working on the 4D model by Navisworks and Revit, I found a way, it is very effiecient but bears some malfunction. For each level-stuff you want to select, you can set the View Range just as the same as the height of the level and then select by filter, most of the stuff are the ones on the very level(with some exceptions that some objects go throungh several levels).
Thanks!
No7playground
demo wall schedule "by floor" |
Fri, Apr 1, 2005 at 1:43:15 AM
Walls show up on Second Level plan |
Wed, Dec 19, 2018 at 8:39:24 AM
Level Consraint on a room. |
Thu, Jul 30, 2009 at 1:52:00 AM
top/base constraint as a parameter in family types |
Wed, Sep 9, 2009 at 4:49:38 PM
Overhead wall and Level 3 are not aligned |
Thu, Mar 17, 2016 at 10:17:42 AM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
