88 Users Online (89 Members):
Forums >> Revit Building >> Technical Support >> GeodesicDome and space frame
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Hi guys! How to do a geodesic dome space frame with diamond shaped glass panel? The normal family creation only yields rectangular shaped glass panel.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
Hmmm, not currently possible AFAIK in any automatic way as you cannot rotate grids associated to a curved plane.
One method would be to create a surface in another program that creates the desired faces to the shape desired then import that in and use it as mass to associate curtain walls to.
Or create a family for the diamond piece with a slope then radial array 180º it at the varying angles.
HTH
Thanks Mr Spot for your input. I understand that you are final year students in architecture. Maybe we can share our experinece.
Sure, email me if you like.
making space frame in revit. |
Tue, Dec 21, 2004 at 5:15:38 PM
geodesic dome space frame |
Sat, Apr 2, 2005 at 7:42:13 AM
Inner space is not surrounded by outer space with higher height. |
Thu, Sep 6, 2012 at 8:34:57 AM
HoW CAN Ä° CUT A SPACE FRAME STRUCTURE ? |
Mon, Jan 6, 2014 at 7:27:56 AM
Seperating steel frame ( NEED HELP) |
Mon, Aug 15, 2016 at 10:38:37 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
