Forums >> Revit Building >> Technical Support >> pat files
I am trying to create a pattern file and i cant seem to do it. I followed the example given in the help but when i try to import i get an error that reads " 3rd line syntax error import aborted" does anyone know why this is happening? Here is the file as it reads now *Slate Tile 16" x 24". ;%MODEL. 45, 0, 0, 12, 36, 36, 12 45, -12, 12, 12, 36, 36, 12 -45, -12, 36, 12, 36, 24, 12 -45, -12 48, 12, 36, 24, 12 Any info would be of great help.
![4 Stars: 4 Votes](/images/stars_4.gif) |
try changing your 12 at the end to -12. They way I view the numbers is as follows: angle, x offset, y offset, shift (left or right), distance to next repeated line, and then how long to pick the pen up. I always have -# at the end of the line, and I think of this as the pen being picked up... It works for me, maybe it can for you...
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
try this: *Slate Tile 16" x 24". ;%TYPE=MODEL 45, 0, 0, 12, 36, 36, 12 45, -12, 12, 12, 36, 36, 12 -45, -12, 36, 12, 36, 24, 12 -45, -12, 48, 12, 36, 24, 12 Here were your problems: -You needed the %TYPE= in front of the pattern type. -The last line, you were missing a ',' after the '-12' After this I was able to import the pattern fine.
Edited on: Wed, Jul 2, 2008 at 2:50:34 PM
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Pat Files |
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ] |
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files |
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder? |
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files |
Fri, Oct 21, 2005 at 3:13:23 PM
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
