112 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Nested families
Mon, Apr 11, 2005 at 8:15:38 PM | Nested families
fkremkus
I made a door family that has two nested window---- within the family editor the wall opening are working correctly but once I insert the family into a test file that has a wall the window openings do not cut the wall as they should. The openings are created as a void cut to allow for the masonry return, does this pose the problem? Please advise. Best regards, Fabian
Tue, Apr 12, 2005 at 10:00:23 PM | RE: Nested families
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
Try using an opening as opposed to a void
Hiroshi Jacobs
Tue, Apr 12, 2005 at 10:35:41 PM | RE: Nested families
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Haven't tried this, but what if you include a void in the combination family that is set to cut the wall.... It won't therefore have to cut in the family but will cut what the other windows aren't cutting in the project.... Ohh i even confused myself with that sentence. Nested voids in families haven't never been able to cut more than 2 levels deep. Family--Family-- Project = 3 Levels. Family--Family = 2 Levels and thus works as does Family -- Project. HTH.
Tue, Apr 12, 2005 at 11:08:53 PM | RE: Nested families
fkremkus
Thanks for your replies I can not make it an opening in the window family because the opening modeling tool does only allow non proflie 2d cuts and that would compromise the masonry returns. But what about a hierarchy change? family door(opening) into family window(void) into project or making an inplace void family? I tried the above and the only way I could make it work is inserting another window family that only consists of a void. I placed this on top of the window / door and recut the wall. This way it displays fine and generates a window and a door tag. Thanks again, Fabian Post edited on 2005-04-13 00:03:29
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Page generation time: 0.7297
