Forums >> Revit Building >> Technical Support >> elevation tags
Mon, Jun 30, 2008 at 4:58:59 PM | elevation tags
emasters
My ground floor interior elevation tags are showing up on the second floor as well as the ground floor, second floor tags on the third floor, etc. The view range of the elevation is limited to only one floor and the volume of the room is limited to that floor as well.
My office recently upgraded software from 2008 to 2009 and did not have this problem previously.
Any suggestions? Thanks!
Tue, Jul 1, 2008 at 11:32:38 AM | elevation tags
tim123
4 Stars: 19 Votes
Size your elevations so that the height only shows the relevant floor - if the floor thickness of the floor above is included then hte symbol will show in that plan.
Hope that helps.
Tue, Jul 1, 2008 at 2:27:02 PM | elevation tags
emasters
Thanks for the advise!
A coworker of mine actually figured out that the associate level in the view range for levels 2 and 3 had been set at the wrong level.  I think it must have gotten shifted during the upgrade to 2009. All of our tags had to be re-added after the upgrade as well. Has anyone else had any strange problems like that in the upgrade process?
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags
Mon, May 24, 2010 at 3:20:16 PM
Page generation time: 0.7447
