65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Modifying the default tags
4 Posts No Rating |
Is there a way for me to modify the appearance of the Interior Elevation Tags? I was able to change the appearance of the door tags by using the Edit Family command, but I am not able to modify the interior elevation tags by using the same concept. Thanks in advance for you help on this one. JDH2
Unfortunately, elevation tags are not editable in appaerance. This is an issue that has been fought for a LONG time with Revit and unfortunately has not had an opportunity to be addressed yet. The workaround would be to make an annotation component that looks the way you want it to and hide the elevation tag that revit uses. HTH.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Modifying Default Family Templates |
Mon, Apr 26, 2010 at 2:20:23 PM
Structural Element Tags |
Fri, Oct 3, 2008 at 11:27:10 AM
Adding default tags |
Tue, May 15, 2007 at 12:35:35 PM
finding default shared paramaters |
Sun, Feb 1, 2009 at 5:21:18 AM
Building Elevation Tags |
Thu, Feb 17, 2011 at 9:32:02 AM
Members: | 2017265 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
