55 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> font styles - want to use arial
a basic question Just reading through our office cad standards and there is a line stating that every1 should be using romans.shx as the font of choice in Autocad as it is the most economical in terms of disk space and regeneration times of other fonts. Is this the case within Revit???
.shx fonts cannot be used in Revit. HTH
yes, my post got the reply it deserved as I wasn’t implying that I wanted to bring the Autocad Roman font. I just wanted to know if any1 had done tests of file size etc with different fonts.
Edited on: Mon, Jun 30, 2008 at 5:57:20 PM
I think this used to be the case with AutoCAD but the memory usage for non shx fonts hardly makes any difference to a drawing now - no reason to use shx fonts even in AutoCAD. There is a RomanS font in Revit but we have found it does not work that well and use Arial.
cheers mate Thankfully I have set up all our templates, tags etc to use Arial.
What have I done wrong with this window? |
Mon, Oct 15, 2012 at 2:55:10 AM
Material ID and Element ID |
Tue, Sep 23, 2008 at 8:26:51 AM
Can't copy Lights - "Can't place inserts outside of hosts. ! |
Thu, Oct 11, 2012 at 6:32:37 AM
Material Hatch Visibility |
Tue, Apr 15, 2008 at 1:53:41 PM
Dimension |
Mon, Apr 14, 2008 at 1:53:57 PM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
