Forums >> Revit Building >> Technical Support >> room bounding parameter in wall
Fri, Jun 27, 2008 at 8:16:41 AM | room bounding parameter in wall
zabel
In R Arch 2009, I modified a wall family to work as my toilet partition.
It's currently room bounding, and when I look in the Element Properties, that box is checked as expected.
I want to turn room bounding off, but the parameter is greyed out so I can't UNcheck it.
When I click on Edit/New, I don't see anything there either.
Fri, Jun 27, 2008 at 10:04:31 AM | room bounding parameter in wall
TABEST
4 Stars: 4 Votes
if you have worksets enabled, make the element editable (right click-> and you will see the command).  Then go into element properties.  Sometimes, a checkbox will appear greyed out, but you can check on it twice (the first one causes it to ungrey, then the second one unchecks the box).
Fri, Jun 27, 2008 at 10:12:09 AM | room bounding parameter in wall
zabel
Aha!  It was easier than that.User error: I was trying to apply it to the family in general (nothing selected in the model), rather than selecting a specific partition and viewing its Element Properties.I'm noob enough that some of these basics trip me up. Then again, even if I had the experience I might be in the same boat.D'oh!
Thanks for the added insight, Tabest!
Fri, Jun 27, 2008 at 10:17:07 AM | room bounding parameter in wall
TABEST
4 Stars: 4 Votes
no problem, glad you figured it out, and I struggled on the visiblity graphics overrides and all of that fun stuff for a long time (why is everything so curse nested in this application?).
room bounding problem
Fri, Jul 28, 2017 at 4:03:50 AM
13
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:31 AM
Stairs as Room Bounding
Mon, Jul 9, 2007 at 10:34:26 PM
Opening Tool / Room Bounding
Fri, Jun 18, 2021 at 1:32:48 PM
Ceiling not bounding room
Wed, Oct 6, 2010 at 4:01:35 PM
Page generation time: 1.5440
