Forums >> Revit Building >> Technical Support >> Transfer Project Standards - 'Filter' colour fills not transferring
1 Posts No Rating |
We are using Revit Architecture 2008 (Build: 20070324_1700).I am currently working on a large college project, which consists of three separate buildings, with a model file for each building.I need to set-up 'Filters' and 'View Templates' for wall/partition layouts and Fire Strategy layouts respectively. I planned to do this in a template file, which I would then transfer over to the individual models, using the 'Transfer Project Standards' function.In the template, I set up filters, and in view properties, I define the colour fill for each filter category - and then I set up and name the view templates accordingly.In the Transfer project standards options, I tick/select Colour Fills, Filters, View Templates and Wall Types to be transferred.In the resulting model, the wall types, filters and view templates all transfer successfully - however, when I apply the view template to the respective view, the colour fills don’t appear - so I go to Visibility/Graphic overrides (VV) in View Properties, switch to the Filters tab, and the filters are listed but not colour fills are associated with each filter name.For the wall/partition types, we are using a lot of different colours, due to the no. of differing wall types/conditions - if I (or someone else) needs to set the colours on each model after transferring the standards, it could lead to errors/inconsistencies and defeats the purpose of being able to transfer 'standards' between models.Is this a bug of the function, or am I doing something incorrectly? Or does anyone know of a different way of transferring filter/view template setting between models?Cheers for any advice offered.MJ
First off, sounds like you might be working harder than need be... where are your sheets residing? If you have a "campus" file, and your sheets reside in there, then that s where you want your filters to reside. You don't need them in the linked files, unless you are printing sheets from within them also... And I agree with you, it would seem like a bug, but autodesk would "As Designed" that bug, because I think they didn't think it through. Anyway, to do it as you wanted to do, you'd have to "know" which color & settings go to which filter, and then manually enter them into each project.
TRANSFER PROJECT STANDARDS??? |
Thu, Jan 8, 2009 at 1:27:38 PM
Revit 2015 - Transferring Project Units and Mechanical Settings |
Thu, Jan 7, 2016 at 8:12:08 PM
transfer project standards - line weights not transfering |
Mon, Jan 11, 2016 at 11:20:54 PM
Transfer Project Settings |
Fri, Apr 13, 2007 at 4:56:33 PM
Transferring Legends From One Project To Another |
Fri, Dec 22, 2017 at 2:56:18 PM
Members: | 2104439 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
