67 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sheet Title Text
Mon, Apr 11, 2005 at 9:00:36 AM | Sheet Title Text
gY
How can I get more than one line of text in the sheet title without an elongated line of text in the project browser and with out manually changing an extra label. e.g. for multiple buildings in one drawing set building name proposed level 1 floor plan
Mon, Apr 11, 2005 at 1:39:24 PM | RE: Sheet Title Text
arnosandoval
5 Stars: 3 Votes
IT HAS TO DO WITH THE CONSTRAINTS OF THE TEXT WINDOW. THE MORE YOU TYPE THE WITHIN THAT WINDOW THE MORE LINES YOU ARE GOING TO GET. tHIS IS SOMETHING YOU NEED TO MODIFY IN YOUR TITLEBLOCK.RFA FILE. HTH
Title Sheet text sent to back? or transparent?
Wed, Mar 4, 2015 at 3:25:01 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:27 AM
Title block text
Sun, Aug 21, 2016 at 11:07:04 AM
MISSING TITLE TEXT
Fri, May 30, 2008 at 10:44:25 AM
Sheet title block plots incorrectly
Wed, Nov 3, 2010 at 10:44:31 AM
Page generation time: 0.6066
