62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> People in Revit
Thu, Jun 26, 2008 at 5:05:54 PM | People in Revit
jcoleman
How do you place semi-transparent people in a rendered image so you can still see the image that exists behind them?  Is there a way to alter the people in Revit 09?
Wed, Apr 22, 2009 at 11:44:17 AM | People in Revit
joshbarnes2
either edit the element properties, or do it in photoshop.
Fri, May 1, 2009 at 10:44:54 AM | People in Revit
tim123
4 Stars: 19 Votes
You can trace the silhouette of people and extrude them.  Give them a semi-transparent material.  It works quite well, but you have to change the angle of the people in plan to face the camera.
Fri, May 1, 2009 at 11:23:23 AM | People in Revit
erland73
erland73 Avatar
4.5 Stars: 85 Votes
What I´d do is to import a 3d person from i.e. Sketchup and as Tim says give him a semi-transparent material, so you won't have any problems facing that person to the camera....
Sat, May 2, 2009 at 3:22:55 AM | People in Revit
tim123
4 Stars: 19 Votes
Erland has a good solution, but I quite like the effect of losing the 3d detail.  If the camera is far from the people you probably would't notice that though, so much better if you need loads of views from different angles.
Where are the people?
Sat, Jun 21, 2008 at 6:19:10 AM
New revit people for sections and elevations.
Fri, Oct 17, 2014 at 4:10:15 PM
3D People!
Thu, Sep 22, 2011 at 8:33:26 PM
How many people can/should be in a single revit file at one time?
Mon, Mar 30, 2015 at 7:31:08 AM
putting people in a walkthrough
Fri, Jan 25, 2013 at 12:20:06 PM
Page generation time: 2.3721
