128 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Arch Link
Thu, Jun 26, 2008 at 10:55:40 AM | Arch Link
AlexDring
1 Stars: 1 Votes
When i turn on my arch linked model all i see is doors and windows.  In order to see the walls i have to turn the view discipline to architectual.  Is there a way to see the walls without doing this, it gets old having to keep changing over and over
Fri, Jun 27, 2008 at 5:28:49 PM | Arch Link
emgeeo
3.5 Stars: 7 Votes
If you are using structure, set the view to coordination.
The easiest thing to do is set up a view template you can apply to each view.
 But, most important!  Have this as a default in your template.  Having a good template will save you tons of time with view and visibility properties.
Unfortunately, you can't create view templates for a linked-model visibility settings.  I hope this changes for 2009!
Fri, Jun 27, 2008 at 5:31:50 PM | Arch Link
AlexDring
1 Stars: 1 Votes
Cool thanks
When I import REV. ARCH Link, it lands way outside my work space
Fri, Oct 9, 2009 at 12:22:40 PM
Arch link on top of Structure
Wed, Jul 20, 2011 at 4:27:19 PM
Central File & its Arch link - disappeared!
Mon, Aug 29, 2011 at 2:54:22 PM
Arch Link and wall view ranges/visibility graphics
Wed, Apr 21, 2010 at 10:06:47 AM
Printing Arch. Sheets through the link
Tue, Aug 11, 2009 at 10:58:26 AM
Page generation time: 1.1786
