61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Foundation Thickening
Thu, Jun 26, 2008 at 3:47:56 AM | Foundation Thickening
MartinGT
1 Stars: 1 Votes
Hi all
I have a strip foundation that I added to my drawing.  The foundation is supporting a cavity wal, I have added a foundation -> wall.
Now, at certain positions along a length of wall I have a wider foundation due to increased loads.  The only way to get bigger foundations in these position to my knowledge is to use different walls?
OR
Just draft it on?
Any thoughts?
Fri, Jun 27, 2008 at 5:34:35 PM | Foundation Thickening
emgeeo
3.5 Stars: 7 Votes
This is how I would go about it.
1.  Set up a new footing type for the wider footing.  I assume you want, for examples, a continuous 2'-0" wide X 1'-0" to transition to a 3'-0" wide X 1'-0" continuous footing.  If you are talking about changing depth of the footing from 1'-0" to 1'-6" then we are talking about different things.
2.  Use a reference plane parallel to the wall where the wider footing will start and end
3.  Split wall at reference plane.
4.  Add foundation -> Wall
5.  Select your new footing type
6.  Click section of wall.
7.  Erase your reference planes!
Does that make sense?
Edited on: Fri, Jun 27, 2008 at 5:38:33 PM
Thu, Jul 3, 2008 at 9:27:51 AM | Foundation Thickening
MartinGT
1 Stars: 1 Votes
Used the split command in the end, but didnt seem to need the ref plane?
Thanks anyway
Thu, Jul 3, 2008 at 9:39:53 AM | Foundation Thickening
emgeeo
3.5 Stars: 7 Votes
Personal method- i usualy use this with multiple footing steps...
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:12 AM
slab thickening below hardcore
Wed, Jan 12, 2011 at 5:26:22 AM
Adding Reinforcement to a Custom Slab Thickening Family
Fri, Apr 30, 2010 at 12:27:09 AM
Hidden line Help!!! Please!
Wed, Sep 19, 2007 at 2:33:35 PM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:02 AM
Page generation time: 0.2286
