40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> breakline
Wed, Jun 25, 2008 at 4:31:01 PM | breakline
mdcoop
I am using Revit 2008 and am having trouble using the breakline family.  It isn't masking objects within views.  Is there a different version of this or something I can do to alleviate this problem. Thank you in advance...
Wed, Jul 2, 2008 at 2:37:52 PM | breakline
TABEST
4 Stars: 4 Votes
give this a try.
Thu, Jul 3, 2008 at 11:09:48 AM | breakline
emgeeo
3.5 Stars: 7 Votes
I believe your visibility graphics needs to be set to hidden...
Thu, Sep 18, 2008 at 8:25:18 PM | breakline
andfarming
when will we have a breakline that scales to the view?
 I tried to create as a symbol, but shape handles won't work and masking covers levels / grids.
Thu, Sep 18, 2008 at 8:31:02 PM | breakline
andfarming
Thu, Sep 18, 2008 at 9:40:08 PM | breakline
Asidie
I think you could make it by creating a parametric annotation familly, with a masking region. then you can set the dimensions that will be view-specific.
 M.
Fri, Sep 19, 2008 at 7:10:01 AM | breakline
3.5 Stars: 395 Votes
The out of the box breakline is fully parametric.  Just grab the handles and adjust it.  Width - masking region - break 'z' all adjust.  If you add an element afterwards, you may have to reset which item is on-top (draw-order).
very minor problem with annotation RAC2009
Thu, Jan 8, 2009 at 4:44:21 PM
Changing section callouts and breakline symbols (lineweights, types)
Fri, Dec 28, 2012 at 8:37:44 AM
duplicate detail families
Mon, Oct 22, 2012 at 8:14:03 AM
Civil 3d surface to revit topo surface
Tue, Nov 2, 2010 at 2:37:59 PM
Break line in elevation
Fri, Nov 21, 2008 at 1:01:49 PM
Page generation time: 0.8739
