113 Users Online (112 Members):
Forums >> Revit Systems >> Technical Support >> haet colling load calc.
![DESIGN4BUILDING Avatar](user_avatar/20306.jpg)
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
i get a message revit was unable to identify any spaces... something about phase matching and project phase setting, any one not what is not turn on or sometine. tks
2 Posts No Rating |
What have you already done? Have you copy/monitored the rooms from the architectural model or have you specified the rooms. Make sure rooms are inclosed spaces. Add the properties and function to the rooms, best to be done in the room schedule. Running the Load calc then should work. Make also sure that you are on latest built of the revit software. If you are using an earlier version, the load calcs do not work whatever you are doing with the rooms. Latest builts can be downloaded from the autodesk revit website, see support & services. Vokay
im useing all 2009v of arch. and mep. somehow im not creating spaces or somethig, i use room area tool to creat rooms and tags (area and volume) for them,no prob. and i follow the instructions that come w/ software to create a zone but still get the message that i talked about above.... PS no i have not copy/monitored the rooms, dont now about that ill reaserch
Edited on: Fri, Jun 27, 2008 at 4:43:19 PM
3 Posts No Rating |
If you want to use load calculation, you must define space in your MEP model. 1. First Link with Architect Model, 2. You must check link model property (under project borwser - revit links), Room bounding must check mark. 3. Then you apply Space. 4. Optional, you can make zone for those spaces. I also very new in Revit. Now I start using Revit MEP 2009. Do you have any sample MEP project for reference?
im great at revit archi. but new with mep, i have a lot of drawing but none w/ linked, monitor, or any like that. i know how to create room spaces w/ tags and sf and volumes but in mep no calcs.
Heating & cooling calc |
Wed, Nov 13, 2013 at 9:56:26 PM
Can Revit 2011 or 2012 Separate Zones in to Systems to be ran in Load Calc |
Tue, May 17, 2011 at 5:06:45 PM
area calc schedule |
Fri, Oct 17, 2014 at 10:14:00 AM
light vent and egress automated calc |
Mon, Jul 14, 2008 at 12:06:08 PM
Heat loss calculation formula |
Wed, Sep 24, 2008 at 3:16:36 PM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
