133 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sweep wrap around external walls with opening
Wed, Jun 25, 2008 at 9:52:14 AM | Sweep wrap around external walls with opening
Jays08
I have encountered a problem while using sweep for a wall.  The sweep does not wrap around the wall incase of an opening in the wall.  The attached image will tell you the situation i am in.  while using external walls in corridors or balconies, if I have a sweep around the wall base, it only cuts off wherever there is an opening or an insert.  Unlike the compound walls that wrap material around the inserts, sweep does not wrap around.  I tried using the primitive revit method of using a thin wall to make a box  around the main wall so that the sweep wraps around.  But in actual construction drawings, I would look like a fool if I did that.  Please help me with this.  Thanks.
Wed, Jun 25, 2008 at 10:55:56 AM | Sweep wrap around external walls with opening
BRIANHADLEY
If it is a wall sweep select the wall sweep then select change sweep returns make sure that the angle is specified at 90 degrees then select the end you want returned.
sweep wont wrap my inplace component
Thu, Sep 29, 2011 at 3:28:10 PM
Help required with wall wrap at window & door jambs
Fri, Oct 16, 2015 at 4:57:20 AM
Louvers/External Shading
Mon, Jan 8, 2007 at 11:13:09 AM
Failure of Base Wall Sweep to Wrap at Insert! Help!
Sat, Mar 3, 2007 at 10:31:10 AM
wall closure wrapping at doors, curtain walls
Fri, Apr 15, 2011 at 10:50:27 AM
Page generation time: 2.5474
