161 Users Online (159 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Breaking wall sweeps
Tue, Jun 24, 2008 at 3:20:06 PM | Breaking wall sweeps
BRIANHADLEY
Is there a way to break or split a wall sweep.  I am using a sweep for a wall cap on a parapet wall.  I need to break it to add  small decorative precast pieces at intervals along the wall cap.  I would also like to show the sweep return at each break.
Tue, Jun 24, 2008 at 3:41:45 PM | Breaking wall sweeps
mhans
3 Stars: 10 Votes
There's this blue dot at your sweep ends. Drag them as you like. You can copy them along the same line, just unchecked the Constraints button at the option bar.
Motto: "No Post left behind"
Tue, Jun 24, 2008 at 6:27:58 PM | Breaking wall sweeps
BRIANHADLEY
I tried that but when I copy it tells me "elements deleted"  and then nothing is copied.
Tue, Jun 24, 2008 at 7:38:42 PM | Breaking wall sweeps
mhans
3 Stars: 10 Votes
Do you mean something like this?
Tue, Jun 24, 2008 at 7:44:05 PM | Breaking wall sweeps
timbo89
timbo89 Avatar
4 Stars: 5 Votes
mhans, I would like to know how to do that also. Could you please explain how you did that?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Jun 24, 2008 at 7:54:11 PM | Breaking wall sweeps
mhans
3 Stars: 10 Votes
Do a Host wall sweep from Modelling Tab on your wall (any profile). Revit won't allow you  to overlap sweep. So before doing a copy of the sweep, drag the blue dots on either end to size your sweep. From the elevation view, you can make a copy of the sweep along the same line or some other place on the same wall (uncheck your constraint to copy elsewhere).
Wed, Jun 25, 2008 at 10:41:53 AM | Breaking wall sweeps
BRIANHADLEY
I keep trying this, but I get the same message "elements were deleted".  I know I have made this work in the past.  Could it be a problem with 2009.  I just updated to the latest build.
Wed, Jun 25, 2008 at 12:53:19 PM | Breaking wall sweeps
mhans
3 Stars: 10 Votes
Try offsetting your sweep with a small gap from your opening. If the sweep aligns with the opening, it cuts itself automatically and if it's the same length with the opening it will be deleted.
Wed, Jun 25, 2008 at 4:25:38 PM | Breaking wall sweeps
BRIANHADLEY
Im not sure what you mean.
Wed, Jun 25, 2008 at 7:00:51 PM | Breaking wall sweeps
mhans
3 Stars: 10 Votes
See attached image.
Wed, Jun 25, 2008 at 7:20:02 PM | Breaking wall sweeps
BRIANHADLEY
I can see the image but the text is too small.
Sun, Jan 17, 2010 at 6:38:35 PM | Breaking wall sweeps
col9000
I know this is a very old thread, but I was having the same problem ("element was deleted"Winking when using Copy make separate segments of skirting board. I found that it only works if I copy the new segment onto a different sweep path (i.e. I copy it slightly up the wall), then I can move back down to floor level. Maybe there's a better way, but it works at least...
wall sweeps and after breaking up a wall
Tue, Jul 17, 2007 at 12:40:23 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:42 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:56 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:47 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:06 AM
Page generation time: 1.9061
