110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Split Region and Rendering Questions
Tue, Jun 24, 2008 at 8:05:22 AM | Split Region and Rendering Questions
JGATOR
I am using Revit 2009. I have a two bldg project. They are basically a mirror of each other. On the west wall of the west bldg I needed to use split region to create a area with a different color on the wall. I have to make the same area on the east wall of the east bldg. I go to the east elevation and select the wall for the split region and it gives me the west wall of the west bldg and it won't let me create the region. I tried using a slightly smaller region and that doesn't work. I tried selecting the wall first then the command but you have to reselect the wall and I get the west wall again. Any fix on this?Same poject, I want to render a 3D view then move it over to a 24x36 sheet. I move it over to the sheet and it is very small. I go back to the rendering and change the scale to 1:1 and it is still too small. I use the custom feature and try to go 1:-2 and that doesn't work and box comes up that says I must put in an integer. What can I do to make it bigger?
Tue, Jun 24, 2008 at 8:40:57 AM | Split Region and Rendering Questions
4 Stars: 203 Votes
Sincerelly i don't understand what's the problem in split the walls.... the error "I must put in an integer" it's because you put the sign "-"
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:02 AM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:26 PM
Walls, Split regions and Materials
Fri, Jan 20, 2006 at 3:13:13 PM
SPLIT REGIONS
Thu, Feb 11, 2010 at 12:16:10 PM
Split region on a wall surface Revit 2010
Thu, Feb 11, 2010 at 2:18:08 PM
Page generation time: 1.6922
