Forums >> Revit Structure >> Technical Support >> Splines to Polylines
I have a tricky curved slab outline to do in Revit and as usual the information from the Architect is in the form of splines!! as Revit does not recognise these i need to convert the splines to plines without loosing the curved geometrey! This one has been giving a lot of people headaches so any info is very welcome.. Cheers
REVIT does do splines, it does not do plines.
The question wasn't if Revit could draw splines and polylines...the question was how to get an AutoCAD spline into a format that Revit will RECOGNIZE... I'd try freehanding a spline until you can come up with a better solution...I'll look into it though Anyone else?
things are still the same http://www.revitcity.com/forums.php?action=viewthread&thread_id=7416
I couldn't find a way to convert splines into polylines (via autocad), although it looks like you can convert polylines into splines? Another, and probably less desiralbe and slightly more intensive procedure might be to: In AutoCAD 1. Use the divide comand on the spline 2. Specify the number of nodes (depending on your level of acceptable tolerance) 3. Draw a polyline from point to point (I recommend setting your OSMODE to '8'- your current OSMODE will be displayed in AutoCAD default brackets '< >' and should be noted to easily change it back when you are done with this procedure). 4. Save In Revit 5. Reload the CAD background 6. Create/edit a slab 7. Use the pick line command and tab through until you get your string of lines. From what I can tell this geometry shouldn't be too taxing on your machine. 4.
Enter sketch mode for your slab and import the .dwg file selecting the layer the spline is on. the result will be native Revit splines. I generally find that a closed spline in AutoCad will result in two splines within Revit but I find that much more managable than amultiple small lines.
Edited on: Mon, Jul 7, 2008 at 7:29:02 AM
NICE!
Export Room Polylines and Area Polylines to same DWG ? |
Wed, Aug 24, 2016 at 5:33:53 AM
3d splines into Revit Structures 2011 |
Thu, Nov 10, 2011 at 2:02:27 PM
revit freezing and not responding when cad file linked |
Fri, Feb 6, 2015 at 11:24:57 AM
Polylines? |
Mon, Mar 25, 2013 at 2:40:58 PM
How do import curvilinear CAD lines into Revit for editing? |
Tue, Mar 9, 2010 at 7:11:03 AM
Members: | 2115311 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
