121 Users Online (119 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New materials RAC 2009 and or new skies/backgrounds/environments??
Mon, Jun 23, 2008 at 3:33:59 PM | New materials RAC 2009 and or new skies/backgrounds/environments??
elvis
Hi all,
how to save newly made materials to the proteinlibrary with a new name? and are there more materials available somewhere? i can't figure out how to save my new materials and how to give them a unique name!
The same for new skies and environment settings? how to made a new sky and environment setting, for example a sky by night etc, andhow to make this selectable next to the default skies etc.
GrtzE
Fri, Jun 27, 2008 at 7:59:07 AM | New materials RAC 2009 and or new skies/backgrounds/environments??
elvis
Are there additional material libraries for raytracing in RAC2009?
Fri, Jun 27, 2008 at 8:01:44 AM | New materials RAC 2009 and or new skies/backgrounds/environments??
elvis
Is everyone then using the default skies in rac2009 for the rendering?
how to create an new sky with nicer clouds or whatever, i know ho to make the *. EXR files, but how to load these as preset??
Fri, Jun 27, 2008 at 9:52:35 AM | New materials RAC 2009 and or new skies/backgrounds/environments??
4 Stars: 203 Votes
Hi, you must render in revit and then go to Photoshop and "Put" the background (the sky you want).
Thu, Jul 17, 2008 at 3:54:29 PM | New materials RAC 2009 and or new skies/backgrounds/environments??
blackhawk
3.5 Stars: 3 Votes
That has also been my experience as the skies in revit can be unpredictable. At times, the sky does some amazing renderings...but more often than not the sky is horrible. When you export your rendering, it's easier to export as a bitmap then use the alpha channel in photoshop to add your background image.
Thu, Jan 22, 2009 at 6:38:25 PM | New materials RAC 2009 and or new skies/backgrounds/environments??
ArqRatso
I find it is a real shame that one can use whatever image as background on Elevation Views, but can't create any new skies i.e. for renderings...
Or is there a "secret" way to do it?
Can anyone share?
Thu, Jan 22, 2009 at 7:03:19 PM | New materials RAC 2009 and or new skies/backgrounds/environments??
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
put your background image in a drafting view, then export your render as a tiff then insert the tiff over your background in the drafting view.
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:22 PM
31
REVIT 2009 - MATERIALS
Tue, May 5, 2009 at 10:01:41 AM
13
Duplicating Materials in 2009
Fri, May 16, 2008 at 1:16:26 AM
RAC 2009 Slow Down - Possible Fix
Sun, Jun 15, 2008 at 8:20:43 AM
RAC 2009 Steering Wheel
Sun, May 4, 2008 at 2:06:08 AM
Page generation time: 0.5078
