66 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> titleblock image
3 Posts No Rating |
I'm trying import an image as a part of a title block family that I have started. Does anyone know how to add visibility parameters to imported images? Because i have our cover sheet, and title block in the same family and there are no visibility settings for images, the raster image appears on every sheet with a title block. Any ideas? Thanks in advance.
Make two seperate families!
"Make two separate familes!"
Make another titleblock family with the image? Then do you insert the second family in the titleblock family or the project?
UPDATE: Just found this. https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Controlling-visibility-of-architectural-stamp-in-title-block.html
Edited on: Tue, Mar 3, 2020 at 10:23:06 AM
image manager to insert.
JPEG image from titleblock not showing... |
Thu, Mar 22, 2012 at 3:11:26 PM
How do I print a Render image on a titleblock?? |
Thu, Mar 22, 2012 at 3:09:17 PM
Titleblock resized after export |
Fri, Feb 7, 2014 at 8:40:39 AM
Image Missing From Titleblock Once Printed |
Wed, Apr 11, 2012 at 8:57:20 PM
How to embed an image into a titleblock? |
Tue, Jan 25, 2011 at 11:22:19 AM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
