145 Users Online (143 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Attaching Columns
Thu, Apr 7, 2005 at 7:02:47 PM | Attaching Columns
belgrade
Does anyone know how to attach columns to the roof? I would like them to behave similar to the walls that can be attached and move with roof.
Thu, Apr 7, 2005 at 9:25:01 PM | RE: Attaching Columns
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Currently not possible... Very unrevit like i know.
Thu, Apr 7, 2005 at 11:22:37 PM | RE: Attaching Columns
riksta
The best way I know is to create a column family and simply add a height dimension as an instance parameter and change the height of the column as required in elevations. Try the one in the attached file. You can adjust width, depth & height as instance parameters. HTH (if the file attaches properly!)
Attaching Columns to Footers
Tue, Feb 24, 2009 at 7:34:30 PM
Attaching columns to roofs?
Wed, Jan 11, 2006 at 5:59:56 PM
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:45 PM
Foundation attaching to a columns analytical line
Thu, Feb 11, 2010 at 10:54:00 AM
Isolated foundations attaching to columns
Thu, Oct 16, 2008 at 5:15:42 PM
Page generation time: 0.2455
