72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Slab not showing in 09
Fri, Jun 20, 2008 at 6:31:04 AM | Slab not showing in 09
Pele
Pele Avatar
I have posted this in the newbies section.
Here goes again. I am learning on 09 & have tried to draw a slab using Lachli Kemlani's Its All About Relationship tut.
I've got to drawing a floor slab but it only shows a pink line around the wall perimeter but no slab is apparent in the model or wire frame elev views?
All assistance greatly appreciated.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Fri, Jun 20, 2008 at 8:21:54 AM | Slab not showing in 09
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you are seeing the pink line that mean you are in Sketch Mode. You need to select Finish from the tab on the left of the screen. As for visibility you can check the Visibility and Graphics menu in the view properties and make sure that the Floors category is turned on.
Showing walls from the bottom of slab
Tue, Feb 9, 2010 at 10:40:40 AM
Stair Showing Below Mezz Slab
Fri, Jan 27, 2012 at 8:21:10 AM
Properly showing slab edge in section.
Mon, May 3, 2010 at 5:27:10 PM
Thickened slab appearance
Fri, Jun 8, 2012 at 10:43:23 AM
Model lines not showing up on slab surface
Sun, May 1, 2016 at 8:30:20 AM
Page generation time: 0.5956
