68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Using families from Steel Select.com
1 Posts No Rating |
Hi, I saved a bunch of families from steel select.com and try to apply them in Revit. I loaded them in and quiet easily applied the gutter types under the properties tab and under edit/new construction - profile. but I dont know how to apply the roofing familes. When I load it into the drawing it comes up under families-profiles in the project browser so I can turn the gutter into roof sheeting but dont know how to apply it to a roof???? any help would be great!!!
Hi, you can add gutter to a roof by "Modeling - Host Sweep - Roof Gutter (or Fascia, if you want to)"...
Look in your help menu using "profile" to learn how this family is used in several applications and how to use it.
Steel connection plates families |
Fri, Jun 21, 2013 at 1:43:40 AM
Fabsec Steel Beam Families |
Wed, Nov 8, 2006 at 1:43:28 PM
Problems opening pre-loaded steel families in Revit Structure 2012 |
Tue, Sep 10, 2013 at 10:26:36 PM
sloped steel? |
Thu, Apr 8, 2010 at 5:51:25 PM
Piping families... |
Mon, Oct 22, 2018 at 9:20:59 AM
Members: | 2022307 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
