98 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Out of Memory 2008 error
Wed, Jun 18, 2008 at 3:37:51 AM | Out of Memory 2008 error
Safety
1 Stars: 1 Votes
Hi All
 I got this pop -up recently and I have 4 gig Ram on my system and can't seem to understand why it would tell me I am out of memory! I didn't have too many windows open and was only running outlook in the background
Any reasons why this could happen?
Wed, Jun 18, 2008 at 3:45:08 AM | Out of Memory 2008 error
4 Stars: 202 Votes
Hi SAFETY, what is the caracteristics of your machine? How many files in revit are open? Did you install the Service Pack 3 from REVIT?
Wed, Jun 18, 2008 at 3:59:17 AM | Out of Memory 2008 error
Safety
1 Stars: 1 Votes
No service pack has been installed and I am running
Pentium D CPU 3.4 Ghz
Xp Service pack 2
 Where do I get Service Pack 3 for Revit?
Wed, Jun 18, 2008 at 4:30:32 AM | Out of Memory 2008 error
4 Stars: 202 Votes
There are 3 Services Pack for 2008 and i had problems before install the SP3... i'm not in my computer right now and i don't remember the complete "Path" but it's from autodesk....
Wed, Jun 18, 2008 at 2:46:58 PM | Out of Memory 2008 error
4 Stars: 202 Votes
Hi Safety look at here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944#section2
Wed, Jun 18, 2008 at 3:03:00 PM | Out of Memory 2008 error
mhans
3 Stars: 10 Votes
I think it's your virtual memory and not your physical RAM that ran out.
Here's some helpful links:
http://revitcoaster.blogspot.com/2006/10/revit-and-dual-core.html
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8018966&linkID=9243142
Motto: "No Post left behind"
Wed, Jun 18, 2008 at 3:25:53 PM | Out of Memory 2008 error
4 Stars: 202 Votes
Hi Mhans, i actually use SMP SEASAW and it's fine but also he aren't install SP1 2 or 3, so...
 About the 3GB enabling i have a bad experience, i was with Xp and now VISTA 64, and solve my problems of memory...
Wed, Jun 18, 2008 at 3:35:50 PM | Out of Memory 2008 error
Depending on how your system is set up, the longer you run REVIT and perform operations, the more memory you use.  Even though you close a window, not all of the memory that was used is released.  If you are doing major revisions or spinning 3D models, this becomes very important.  That is why you will find the recommendation on this site and AUGI to close REVIT completely at least once a day.
I have heard some peomple say that if you minimize REVIT and then bring it full screen again, you will gain a similar release of memory but I can not verify that.
This user is online
Thu, Jun 19, 2008 at 4:05:05 AM | Out of Memory 2008 error
4 Stars: 202 Votes
Hi, this is the right site to upgrade the Service Pack3, select the language then choose: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9262388
Error in RAC 2008-HELP ME
Tue, Dec 11, 2007 at 12:52:18 PM
Error in RAC 2008
Mon, Dec 10, 2007 at 12:46:33 PM
An error in RAC 2008
Sat, Dec 8, 2007 at 1:07:52 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:34 AM
Getting "Not enough Memory" error
Wed, Dec 31, 2008 at 6:43:48 PM
Page generation time: 1.4799
