40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> purge issues
Mon, Jun 16, 2008 at 9:40:22 PM | purge issues
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
I have a family file that originally had a heap of families loaded into the file. Once I complete the fixture I then purge the file to reduce size etc... Now, when I need to re load a family component into the file that already exists (well, one version exists as the purge removed the rest) it wont fully load the component file. Has any1 else had the same issue??
Is there away around this glitch???
Edited on: Mon, Jun 16, 2008 at 9:40:58 PM
Mon, Jun 16, 2008 at 10:25:17 PM | purge issues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm not sure what you mean by
"it won't fully load the component file" what is it doing?
Are you talking about the type parameters not being updated?  Make sure when loading the family you have "override parameters" ticked when prompted.
Regards,
Chris.
Mon, Jun 16, 2008 at 11:26:23 PM | purge issues
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Thanks for the reply Mr Spot
What I am doing is creating a heap of retail fixtures using components - nested families.
After I finish the fixture I then purge the file to reduce size.
If I need to go back to that fixture to make changes ie. load family that already is in the file as I need a different type component.  None of the multiple type components load.  What I have to do currently is delete the component completely then perform a purge.  Then reload the component which then brings in all associated types/options of that component.
I hope this make sense.
Text style that I can't get purge
Wed, Sep 5, 2012 at 8:40:42 AM
purge selected
Wed, Sep 17, 2008 at 10:40:43 PM
Where are Regions in the Purge List
Tue, Feb 14, 2017 at 10:33:22 AM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:09 PM
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:01 PM
Page generation time: 0.7808
