23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RAC2009 - Kwyboard stops working after using Pantone colors
Mon, Jun 16, 2008 at 10:01:52 AM | RAC2009 - Kwyboard stops working after using Pantone colors
jcs001
I am using RAC2009 under an HP workstation 8600, 8Gb RAM with a NVIDIA Quadro FX 1700 graphics board on Windows XP64.
Everytime I use Pantone colors to make my color schemes, my keyboard stops working. Sometimes only a few keys - most common is the Esc, tab and delete keys. After this I have to reboot my workstation again in order to make it working properly. Other aplications work fine, such as Autocad, 3DMax design, etc. This happens only to revit2009.
Does someone has any problem like this? I talked with the Autodesk certified seller and with HP support, none of them were able to solve the problem.
Thx in advance
Mon, Jun 16, 2008 at 3:21:22 PM | RAC2009 - Kwyboard stops working after using Pantone colors
mhans
3 Stars: 10 Votes
It seems an isolated case. Do you always have this trouble? What's you V-card and Mem?
Motto: "No Post left behind"
Tue, Jun 17, 2008 at 5:42:26 AM | RAC2009 - Kwyboard stops working after using Pantone colors
jcs001
Hello
My graphics board is a NVIDIA Quadro FX 1700 512MB
Tue, Jun 17, 2008 at 6:19:59 AM | RAC2009 - Kwyboard stops working after using Pantone colors
4 Stars: 202 Votes
Sometimes my keys (DELETE, ESC and TAB) don't work in RAC 2009, but only if i leave my computer on during the all night, and it's only if i'm working in REVIT....
Tue, Jun 17, 2008 at 6:39:08 AM | RAC2009 - Kwyboard stops working after using Pantone colors
jcs001
Hi,
I have been testing all the applications I have, I left the computer on for more than one night...All them work perfect, only Revit makes the  keys stop working as described.. Did you test yours using pantone?
Tue, Jun 17, 2008 at 1:53:50 PM | RAC2009 - Kwyboard stops working after using Pantone colors
4 Stars: 202 Votes
No, Revit it just RENDER... then in the morning the keyboard is MAD, the delete don't work, the right ENTER transform to " +" key and so one...
Wed, Jun 18, 2008 at 4:37:56 AM | RAC2009 - Kwyboard stops working after using Pantone colors
puzzle
4 Stars: 10 Votes
have had the same problem. with mine it seems to happen after I have made a new material but not always. 2 other friends have had the same problem
Macca
Sunshine Coast
QLD Australia
Tue, Jul 1, 2008 at 2:00:09 AM | RAC2009 - Kwyboard stops working after using Pantone colors
ppinc
Hi All,
I have recently installed RAC 09 and am having the same keyboard issues. This generally occurs when I have gone into the rendering dialogue. My keyboard freezes ad is totally in-operable. I see a few of you have also experienced this and was wondering if anybody had found an answer to rectify the issue at all.
Tue, Jul 1, 2008 at 4:43:00 AM | RAC2009 - Kwyboard stops working after using Pantone colors
4 Stars: 202 Votes
Hi, i just upgrade the SP1 for 2009 but don't fix this issue, until now i don't have any solution...
Thu, Jul 10, 2008 at 12:49:58 PM | RAC2009 - Kwyboard stops working after using Pantone colors
jbenisek
"It seems an isolated case. "   - I love this statement from anyone, programming bugs are not isolated ever we all carry them around and could have them at anytime.
1st if you have this problem please try a keyboard/mouse reset
How to Reset your Keyboard and Mouse:
Left hand "LCtrl+LAlt+LShift" + Right hand "RCtrl+RAlt+RShift" All at the sametime, it sure beats a full reboot. This might take a second to reset before ESC, Keyboard or Mouse work correctly.
I've had 3 reports of these types of problems in Revit 2009 SP1.
First problem was with Mouse Left button and Right button bug where the left button opens the properties but doesn't select or do normal left click action. Right button also opens properties. - Fixed by keyboard reset (Fails in both Windows and Revit)
Second problem was with Esc stops working out of no where. Fixed for a while (30 minutes) by unpluging the keyboard then replugging it in. (Only fails in Revit 2009)
Last problem was with text box that wont let you type in, a keyboard reset fixes this but only for a while (5 minutes) if you keep fighting with it sometimes it comes back. (Only fails in Revit 2009)
These all need to be fixed (ASAP) and are not isolated.
All my workstation are newer than 2 years, Precision 690's+ on XP 32-bit SP2 with Maxed Ram. Revit is SP1.
Edited on: Thu, Jul 10, 2008 at 1:27:49 PM
Thu, Jul 10, 2008 at 1:06:24 PM | RAC2009 - Kwyboard stops working after using Pantone colors
jbenisek
Also the Panton has a bug where windows says the program is busy (retry or switch to program) both fail and now your stuck in a loop.
Temp Fix = Right Hand "Click x or retry" fast after the click x then Left hand "push Esc"
This takes some timing as you have to push Esc before the retry comes back up.
Repeatable by going back into Pantons.
Mon, Jul 14, 2008 at 7:21:24 PM | RAC2009 - Kwyboard stops working after using Pantone colors
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, I had the problem with the keyboard not working after going into pantone to create a new material. The keyboard stopped working in all programs and the only way I could get it to fix was by holding down a few keys very hard for a couple of seconds. I think I'll try the keyboard reset next time. With the switch to new program, I always get that error when I open up the pantone colour library. Does anyone know why it does this, and what program is Revit referring to, as I never know what to close?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Jul 15, 2008 at 1:03:48 PM | RAC2009 - Kwyboard stops working after using Pantone colors
#13
RandyB
I too have this same issue with RAC2009, and it always semm to be about the sametime I access the pantone colors.
The only fix that works for me besides a restart, is to Alt/Tab to outlook start a new mail message and type franticly until the keyboard responds then I Alt/Tab bact to Revit and things are fine.
we need a fix
Tue, Jul 15, 2008 at 1:32:21 PM | RAC2009 - Kwyboard stops working after using Pantone colors
#14
dano3d
3.5 Stars: 3 Votes
 Same problem here.  It got so frustrating that our entire office decided to go back to using Revit-2008 until the bugs are fixed. With Autocad this would not have been a big issue, but since you can't "save back" to earlier versions in Revit it has caused some problems sharing families etc.  Next time an upgrade is released we'll be very slow to make the jump!
Dano
Any possibility of Pantone colors?
Fri, Aug 12, 2005 at 12:39:12 PM
Pantone not working
Wed, Aug 23, 2006 at 8:07:16 AM
Far Clipping Stops working when I zoom in/ out of view
Wed, Jul 16, 2014 at 11:20:39 AM
11
Undo/Redo command stops working
Fri, Apr 30, 2010 at 10:33:35 AM
Pantone colours not printing right
Thu, Dec 20, 2007 at 1:55:41 AM
Page generation time: 0.8557
