Forums >> Revit Structure >> Technical Support >> Remove individual holes from cellular beams
83 Posts No Rating |
Hi RS '08 I've just used cellular bemans for the first time. It appears to work well except I'd like to remove individual holes from the beam where a secondary beam jins it at right angles. Is this possible? Cheers Dave F.
Hi, could you post some images to figure out the problem?
As you can see the smaller connecting beam has nothing to connect to as it's in the position of the hole. I'd like to remove just that hole (& others in a similar position) Hope that clarifies. Cheers Dave F.
Hi again, i see the problem, that beam is a family or is a element you can edit?
Can you put the model to download to see what can i do?
It's a family (see attached) It'sa UK one I think.
Apologies for the double posts – not sure what’s going on!
I just download, i gonna check...
Hi, the beam it's a family and just like you could see have many parameters to control that beam, that it a parameter you can control to solve the problem, i don't know if you figure out yet but you can "move" the holes to the left or right position and in this case it solve your problem, i put you a Video with this: http://screencast.com/t/ovBeKJD7h But if this is not what do you wnat you also can edit that family and change them, but if you are not at ease in working with families i think the best is "create in place" one of this beams and change the hole position how do you want and like...
Edited on: Sun, Jun 15, 2008 at 3:56:07 PM
Thanks for the video - very useful. If I move the holes to miss one beam it hits another, but we're looking into how put them at the correct centres to avoid all. cheers Dave F.
You welcome...
Cellular Beam Families |
Fri, Jan 21, 2011 at 9:27:46 AM
Cellular beams |
Mon, May 7, 2012 at 7:05:52 PM
Cellular Beam (File Attached) |
Tue, Feb 15, 2011 at 3:32:49 AM
cellular beam interuptions |
Fri, Oct 9, 2009 at 1:39:48 PM
Bolt Holes in Columns |
Sun, Mar 23, 2008 at 8:52:37 AM
Members: | 2115654 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
