110 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> curtain wall in wall?
1 Posts No Rating |
Hi,my newbie question is , How must i place in wall curtain wall part (like window assembly in ADT),create a custom door or window family or ? and how cerate window family of a curved glass window in curved wall?
admin
well, you can either create a custom family to your specs or do a curtain wall...it works like any other wall. If you go to the modeling tab, then click "wall"...one of the wall types is a curtain wall. check this link for a curved curtain wall panel:
http://www.revitcity.com/families.php?action=view&family_id=1178
to once you have build your curved wall you will need to insert the curved panel. To do this, hover over the panel you would like to make curved (default is straight even with curved wall) and hit tab until just your panel is highlighted. Then click the panel and it will turn red, click properties and change the panel type to the curved panel.
hope that helps!
Hiroshi Jacobs
The Catholic University of America |
Curtain Wall Panel to Curtain Wall Door |
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall |
Sat, Jan 10, 2009 at 10:01:35 AM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
