51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Updating old projects.
Fri, Jun 13, 2008 at 5:04:39 AM | Updating old projects.
fredc83
I have a couple of projects which were made with an old template file , is it possible to update this file to my new template file(which has a different browser organisation) whitout losing information?  When I link the project i lose some objects and the dimensions.I'm using revit archtitecture 2009.
Thu, Jun 19, 2008 at 8:27:51 AM | Updating old projects.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Have you tried using "Transfer Project Standards". You should be able to get most things from your template to your project by using this. It is not exactly an "all around" solution but it should get you started.
Thu, Jun 19, 2008 at 9:22:15 AM | Updating old projects.
fredc83
thx for your reply, if tried it out but it didn't work. it updated everything (materials, linetypes etcetera ) but it didn't update the tree structure with all the views and sheets. The difference between our old template and new template are these sheets, in our new template there are about 40 extra sheets(and some duplicate views) to print the plans on different papersizes. Maybe someone has another possibility?
Fri, Jun 20, 2008 at 3:45:17 AM | Updating old projects.
Elmo
3.5 Stars: 4 Votes
The only way is to recreate the sheets or to save the sheets out of the project. Those are the only 2 options that you have as far as I'm aware.
updating model
Mon, Aug 5, 2013 at 8:59:54 AM
Workflow for updating a master Revit model with project as-builts [ 1 2 ]
Wed, Oct 12, 2011 at 1:05:43 PM
19
Updating materials in family editor not updating project.
Thu, May 16, 2019 at 12:22:47 AM
Updating year in copyright line?
Fri, Feb 18, 2011 at 11:43:17 AM
Annotation at the family level prior to being imported to Projects
Fri, Jan 16, 2015 at 7:23:36 AM
Page generation time: 0.3062
