Forums >> Revit Building >> Technical Support >> Hidden Objects in Sheet views
2 Posts No Rating |
I have some objects that I'd like hidden (not the entire categories) when I print. I have those objects temporarily hidden, but I don't know how to make them stay hidden when I print. Is there a way around this? ThanksGraham
Hy, you Says "OBJECTS", what kind of objects are you talking about? Mass Elements? Topographics site? what? If you could put some screenshots here to us can figure out, it turns more easy to us understand your problem.... You must tell what version of Revit you use...
Edited on: Thu, Jun 12, 2008 at 4:39:19 PM
If you are using 2008 or 2009, just right click on the object and hide the object in view. Earlier releases do not support this.
2 Posts No Rating |
I'm using Revit Building 9. I was trying to hide a few walls and doors but not all in order to have a cleaner perspective view. I ended up using filters to hide the walls I needed to hide.
objects in view on sheet set not showing up in PDF |
Wed, Jul 10, 2013 at 7:00:03 AM
Sheet Underlay |
Fri, Sep 12, 2014 at 2:13:26 PM
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE |
Fri, Aug 11, 2006 at 1:18:16 PM
Save a sheet of drafting views |
Wed, Mar 1, 2017 at 5:34:29 PM
Print vs View (Consistent vs Hidden) |
Wed, May 1, 2019 at 11:09:02 AM
Members: | 2105868 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
